4X4 TRANS
I WAS THINKING CONVERTER ALSO
TOOK THE OD ASSEMBLY OFF TO DOUBLE CHECK IT.EVERYTHING IS OK
WHEN I REMOVED THE VALVE BODY I ONLY GOT A PINT OF FLUID DRAINING FROM TRANS. I DONT BELIEVE THE CONVERTER IS FILLING UP ON FLUID.IPUT 13 QUARTS IN AND SHOW FULL.
