I just have a hard time understanding. what good a diaper going to do with holes in it.
The diaper has a big depends pad in it to absorb any fluid that spills. The hole for the oil level is a plastic window that is sealed. The drag link holes are open and there is a chance that fluid may escape from that location if the block or pan is windowed in that area, but a majority of the block/pan is covered and the hole is high enough to contain the contents of the pan/block. Some people run a bellows on the drag link that seals to the diaper, but I have not explored that option.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
