Quote: Hi Jim. So far it looks like the front frame rails by the shock towers are bent. Both the front and rear passenger fenders need to be replaced as well as both bumpers, the front valance under the grill and the rear tail light bezel.
Yeti... thats a bummer.. so the a$$end came around and slammed in also... bummer... a good frame shop can pull it back into shape(I use to to frame work years ago at a bump shop)... its not that hard to do if the guys want to spend the time... best of luck buddy
