Quote: I think there should be 4 holes in the face of the waterpump? I built a spanner wrench to hold it while I removed the fan. The belt alone wasn't enough to hold it.
Yup. Exactly. Dodge has a special tool to hold the pulley as you take off the clutch/fan unit. But with a piece of bar stock, 2 bolts, and a drill, you can make a tool to hold the pulley while loosening the big nut on the fan clutch
