Quote: Rod just broke on the small end. still bolted to the crank. spin's just fine. no discolor anywhere. rods have about 200 runs on them when I put them in this motor. new wrist pin bushing and bolts. look them over real good. car ran great on the last time run. no signs of anything wrong. good oil pressure in the staging lanes. wrist pin is still in the piston. I will take some more pics as I get it apart.
Same thing happened with our Hemi motor with Eagle rods last year. Vern described our engine perfectly.
