Awesome vid. Thanks, you are right. I could easily do that although I am having a hard time believing that the pump bolts can hold that power. Bo Duke was awesome BTW. Still looks great. So Ultrabell says you can only use an 11" TC. Will that work in n RV ? Can I get a low stall speed in that size ? Also which flexplate would I want and do I want the diesel a518 or gasser ? IS there a difference ? I would assume there is.
