Just curious, you feel that was a bad track to get down? Grove is a little narrow, but that is one of the best tracks here for traction. The only one better is Mir.
The heat and humidity killed it for tire limited high HP cars. For us to go real fast the track needs to be under 100 degrees and the air temp 70 or lower. The water grains killed our power. We figured we were down about 400 HP to the high humidity.
