Just to shorten up my situation, my body bumpers that are mounted to the bed support frame/cross member are bottoming out on the topside of the axle housing. I have maybe 3/4" clearance between them and the shocks are nearly compressed with it sitting idle on the garage floor.. Make sure you look at that too.
When you decide to quit, THAT is the moment when you would've succeeded..
