Quote: I hope to be there. Engine is being assembled and might be back to my house by Saturday. Just need to install it and the pig with 4.11's (down from 4.56). Having a 1050 Dominator being converted to alcohol to replace the 950HP. That should be back this Monday or Tuesday. Plus a little fabricating to the scoop opening to accommodate the wider carb body and some firewall alterations for the new angle of the throttle linkage rod. If all goes according to plan I'll be there Thursday.
Too bad I don't live closer, I would be there helping out, see you Thursday.
Light travels faster than the speed of sound,,,this is why some people seem bright untill you hear them speak.
