I have a Be Cool radiator with there electric fans. Cools great, but draw a lot of amps? Volt gauge is at 14.5 volts@ 1200 until I kick on the fans then drops to 10-12 volts. There wired on duel relays with circuit breakers to the cut-off switch. Any ideas?
