Re: Electric fans
[Re: Mopar_Ray]
#1482904
08/11/13 05:56 PM
08/11/13 05:56 PM
Posts: 7,506 Az
Crizila
Az
Lose one fan. Smaller alt pulley, Find an alt that has a faster amp curve.
Fastest 300
Re: Electric fans
[Re: Mopar_Ray]
#1482906
08/11/13 06:44 PM
08/11/13 06:44 PM
Posts: 52,972 Romeo MI
MR_P_BODY
It's an east-cost mini alternator one wire, fits the DMI low mount bracket. Think I'm going to try disconnecting one of the fans & see if it stills cool enough.
Sounds like the alt doesnt put out a bunch of amps.. what is the output ![](/ubbthreads/images/graemlins/wave.gif)
Re: Electric fans
[Re: Mopar_Ray]
#1482907
08/11/13 06:50 PM
08/11/13 06:50 PM
MR_P_BODY
You could hook up each fan on a separate thermo switch so one turns on at X temp then if it gets hot enough that the other turns on.. just need 2 thermo switches that you can get at O'Rielys for $18 each ![](/ubbthreads/images/graemlins/wave.gif)
Re: Electric fans
[Re: MR_P_BODY]
#1482910
08/11/13 07:22 PM
08/11/13 07:22 PM
Posts: 512 Illinois
Mopar_Ray
Illinois
That's a great idea Mr P. I put a thermostatic switch in my CSR water pump before I sent parts to my engine builder. My water pump & fans are on a switch. Thought it might be a good idea in case I forgot to turn on switches. Now I have to figure out how to wire?
Re: Electric fans
[Re: Bad340fish]
#1482911
08/11/13 07:32 PM
08/11/13 07:32 PM
Posts: 512 Illinois
Mopar_Ray
Illinois
120 Amp.
http://m.summitracing.com/parts/eca-2003
Next time you need one of those save some money and go to the parts store. Thats a GM CS130 alternator. I have one on my Barracuda and it works great with all of my stuff, one fan, water pump, fuel pump, lights, no problem. I spec'd a 92 buick for my application. It was like $115 with a lifetime warranty.
That's a good idea, il'l keep in mind. I have bought a few parts to later find out there was a cheaper alternitave.
Re: Electric fans
[Re: Mopar_Ray]
#1482912
08/11/13 07:34 PM
08/11/13 07:34 PM
MR_P_BODY
Thats pretty simple... open the wiring harness to the fans and separate them... I run a relay for fans so I use the thermo switch to trigger the relay ![](/ubbthreads/images/graemlins/wave.gif)
