You mentioned it starts to act up at idle, what's happens if you put it to the wood?
Its seems to be able to drive if I give it some fuel but I do seem to think there is a bog or sputter present when it starts to run crappy. Those issues don't seem to be there when it first starts up and is running good.
I have a mopar electronic ignition conversion on it with the chrome box now. It still has the same coil that was on it with the points distributor. (I think that is my old 318 coil but I'm not 100% sure)
2016 Diesel Ram 3500 Mason Dump 1971 Challenger 2013 Jeep Wrangler 1979 Dodge Ram Power Wagon 400 Mini Pumper My other car is a Fire Truck.
