Bill
We questioned lack of oil too. Just checked all cups. No signs of bluing or heat issues on them. Some of the cups do seem to have a thinner wall than some of the others. Oil passages are not restricted. Running 70 psi of pressure in the system. Will order a set of Comp Cams push rods and make them to length at every position to rule that out. Andy. I am running 11 psi of boost 5% under driven. Supposedly 14 psi if I over drive it but the car has plenty for me right now. Andy. Also bought your book on engines but never had time to read it. Got it right as it came out but life had changes and was not interested in the car anymore. Thanks for the help so far guys.
