For the 2nd time, he's NOT asking about B Bodies, why are you being so adamant about dragging B Bodies into this question ?
For the second time you are not listening.
B and E bodies came with 22" radiators with 440 automatic, you made the blanket statement they DO NOT which isn't true. I was just pointing out this was incorrect and pointed out that e-bodies used the same part number radiator as a b-body.
