The firing order sway is basically making it a ford Windsor firing order. Tim
Not really. The offset of each bank of cylinders is opposite with a Ford. The PS bank leads the DS on Fords.
The firing order is the same as LS1 GM.
You take a 5.0 Ford HO motor and turn it upside down and count the cylinders as if it were right side up Mopar or GM and yes it is LS1. Just not close enough to prove your statement.
Leon
Career best 8.02 @ 169 at 3050# and 10" tires small block power.
