is this a power adder motor or N/A. how much separation do you need those ugl cams really limit your choice's.. 60 mm blank cores are not cheap I think comp gets 1000$ for a core but not sure. that is why I used a 55mm cam core.... 300$ core
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
