Some time ago I put a new alternator on my Charger and the lead wire stud rotated in the alternator causing a direct internal ground
Had the exact same symptoms as you describe so if the voltage regulator does not cure your problem or you have messed with the alternator recently it's another place to look. You can test it with an ohm meter from the lead wire stud to the case.
