The link (Red arrow) between the adapter and the kickdown rod needs to be moved to where the black line (black arrow) is in the diagram. The green line and green arrow shows where the kickdown return spring is connected. You may need to lengthen the link a bit or modify the entire bracket to get it to operate correctly through the full stroke of the throttle.
