Are you using an aftermarket heat gauge? Mine also registers between 230-250 but when I check block temp with a laser gauge, it's 180. I'd do that before making any more changes.
http://www.amazon.com/Temperature-Infrared-Thermometer-Laser-Sight/dp/B002YE3FS4
These need to be pointed at a painted surface, if you point it at bare metal, the emissivity of the bare metal will cause errors. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
I didn't do 4 years and 9 months of Graduate School to be called Mister!
