Definitely a light car count today.
I know that some guys that are dialed in on their cars are only coming in tomorrow and Sunday.
Rain and power outages slowed down time trials today.
I think it was between 2 and 3 when cars started making passes.
I finally got to make some passes in mine.
First one it felt like it was missing and not pulling hard at all it ran a 12.91 at 105 mph.
It just felt like crap.
I went back to the pits and checked the timing (36 degrees total) and pulled the plugs and most were wet with gas.
One looked covered in carbon and gas. It was probably the one that was missing.
I made another run this time it ran 11.99 at 111 mph. The 60 ft was 1.72.
Better it it still feels like it's not pulling hard as it should above 4k.
I'll play with it more tomorrow.
The current coil is a stock 40 year old one, that may be part of the problem.
I've also decided that I'm going with drag radials rather than slicks.
I can't stand the loose rear sway at higher speeds with the ET Streets.
