as I posted, have the adj. out of rocker and rod is against rocker. NO clearance???. rod is a mopar mech cup and socket type rod and is a bit shorter than a stock hyd. rod. cam base should be smaller than a stock cam so I don't know why I have no free play
Sounds like your push rods are too long
