Maybe it's me but I just do not see anything that resembles an answer to the actual question asked in this ????
Yeah it's just you . Double R you forgot to add anything that was relevant to his question which means that your post was even less valuable than mine & that's assuming mine was of no value. I would suggest that you go back & edit or delete your post! I had no doubt that someone would opinionate on the best choice of the selections he listed & my thoughts were simply an alternative option that has worked (very well) for me. I even qualitied it with the symbol. Every dist I've modded has provided a vast improvement over stock.
