I use Mopar Performance perches $12.00 or so a set
I relocate the E brake cables when I flip
When you flip you get at least 5 if not 5 1/2" of drop that bracket is the last thing in what I call the dragline zone
It also relieves stress on the cables
Here's a pic of that bracket relocated
so cut off the old and weld on the new then?
also the ebrake stuff is getting cut off. cable is froze and i cant think of a time when ill ever need it.
