the stand up one is to tall for the drop air cleaner, but the rear mount looks perfect, thanks. now about the throttle cable? three peice linkage? i only have a cable? thanks
the bouchillon has a cut to fit throttle cable for mopar.
3-piece linkage is for auto trans kickdown. which mounts on the throttle cable intake bracket.
do you have a manual trans?
