you need alot more tooling than a vertical mill to install cross bolts in a block. the girdles are basically a bolt on with minor machining that any competent shop can do. or you can do at home if you have a vertical mill. won't require you to tilt the head even.
Superior Design Concepts 2574 Elliott Dr Troy MI 48083 jerry@sdconcepts.com www.sdconcepts.com Facebook page: Superior Design Concepts www.bcrproducts.com
