Why change the rods? Rods are body specific all the mounting plate is going to do is slightly move the shifter mounting position, hopefully the floor hump is ok where it is.
I'll only change the rods if I have to. I am hoping that the correct plate puts everything in the right position.
I am not sure where the rods came from, so I am not sure what body they are designed for (which is what started all of this...). I cannot locate the part numbers on the rods anywhere online.
Yeah... I hope the floor hump is in the right place too! I might just to to an auto if that is the case.
383, Hemi 4-Speed, AlterKtion, D60
