RR quick question, its does not matter which slot you weld correct, and it needs to be the inside of "ONE" of the slots...correct? Also how do I determine which spring goes where??
I have found a Old Dizzy and I have the Mr gasket springs on there way here now. need to get the welding done and I can start tuning!!
