Quote: Kim, I'm not sure why you are confused about your wheels. If your broadcast sheet lists code 29 (which is the code for part number 2944329) then wouldn't that be the correct wheel?
I looked for the email but can't find it. Suffice to say that I have gone around this issue in depth twice. If I remember correctly, it was left with the 2944329 not being a real part number (I think it was called phantom but I could be wrong) and there were not any actual wheels that had that number. Rather the real number was something else and on and on and on. I think the person was here who told me this. But if you have a wheel with that number, then that is great and solves the riddle. So, I will be looking for a good set of 2944329s.
