3890 is LONG, like 24 inches extended I think with 9 inches of travel. I've been doing alot of shock research recently and my car (@15.5 inch ride height between shock mounts) needs a 3860 from Afco (6 inches travel, closer to 20" fully extended
just measured from bolt -bolt quick reference and my is about 15.5
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
