Hello everyone
do they make a shorter rear drag shock for a demon, my problem is i put on a comp eng shock part #247-2730 and it's to long when i attach it,....it sit bolt hole to hole collapsed looking for any other make that are shorter.......btw rear end is set up leaf link.........Thanks
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
