Just got home swapped the stage two Hughes engine Eldelbrocks for the airwolfs. I ran a comps cam solid lift and switched to a bullet roller. Everything off the edelbrocks bolted to the airwolfs. The last pass last year the car ran a 6.03. The first pass today was a 5.96 spinning and letting off the big end. Then a 5.86 and 5.87 cutting out on the top end at 116.
