You know that's interssting as I just bought a used LM1 so I could stop guessing where I'm at. thank you for the timely info as I will get it in the recommended range then experimant going a bit richer to see what develops but as is I have no idea if I am way too lean or way too rich. I will call Innovate & ask them if they think it should be sent in to be recalibrated
