On a tough one I'd start back at the basics with a compression test & a leakdown test. Cap the vac adv which will alter the rotor phasing & see if anything changes for better or worse. Do you have another ign system handy to sub in for a test. EDIT got a points dizzy you could sub for a quick test. I think the Pertronix is acting up
