Green bearings will not work with the keyed axle shafts.
I sell a 1 piece axle package for '62-'63 B-body housings.
You must also install '65 and newer brakes.
Any possibilities to disquise the 1 piece axles to look like tapered ones (with the castle nut etc.)? Maybe cutting the hub/end of the shaft and welding them to the flange of the new 1 piece axle?
'66 Plymouth
'64 Dodge
'63 Plymouth x 3
