Quote: That is badass ^^^^^^ I have thought of adding some kind of air extractors at the rear of the hood. What peoples thoughts? Seems you need air through the radiator but why keep it trapped in the engine compartment?
i had an old '68 dart 340. at 140mph the front floated, it felt like you were driving on a cloud. i had good shocks, so it was either the aerodynamics or the tires. or both. at that time i had BFG radial t/a's. i think they are rated for 88mph or something. at very high speeds they are not "stiff enough". you will definitely want rims/tires that have a good design for very high speeds. they will help control the float, along with a proper suspension setup and some aero setup. but dont underestimate the importance of the best rubber you can get under her. whatever tires you decide upon, imagine spinning them at a very high rpm...
