Quote: C'mon Scott, what you are saying is that Chrysler used 100% the right parts no matter what, you know better...
Quote: If a 67 GTX has an unsilenced base plate (the smaller diameter unit that leaves a gap between the lid outer diameter and the base plate outer diameter) it was either swapped after the plant built it or it was a (very unlikely) production line mistake.
