I used some light gauge steel and formed it to the two area's where the floor was a little thin with a ball peen hammer. I then used a heavy weight epoxy and glues the patches to the floor. It's not the best way to go but the metal is too think to weld (I think?) and the biggest hole was only the size of a quarter and not enough to replace the floor pan. I keep reminding myself not to go overboard on this one.
Hopefully I can get the inside of the roof, trunk and roof itself prepped and painted before our legendary order shows up. I have blasted and painted all of the seat frames, seat brackets, etc. and have them in paint now. I sure hope the engine and trans are ok lol
Almost forgot..the gas tank and filler neck are ready to be picked up at the shop that cleaned them up so it's time to test the sndeing unit and order the replacement rubber parts.
