As some on this thread know, mine is a carb inducted 6.1 going in an Aussie A Body...and is getting close to completion.
I run the std aussie steering box location and power brakes. RMVB and no power steer or air con.
6.1 Crate Hemi (Thanks Bob Mazz) $5,250
MSD Harness 88864 $185
MSD 6013 ECU $475
MP Flex plate adapter - P5153753 $85
Jeep Alternator, AL6475X $210
Sump - MIL31000, $205.00
Pick up - MIL18331 $75.95
Dipstick and Tube - MIL 22064 $58.95
Oil plate Adapter - MIL 21566 $34.95
Oil Pan bolts - MIL-85025 $11.95
Oil Pick up stud - 6506333-AA $2.50
Oil Stud Nut - # 6502756 $1.90
Bearing Cap Bolt - 06506272AA $3.70
Oil block off TTI - PN 0200-FBP $68.00
ModMan Manifold - Marsh Performance $490
Electric Fans $120
Champion radiator CC1643 $210
P//Steer delete pulley -Street&Perf $188
Headers - Street and Performance $673
Belt tensioner 4861277AD $30
Tensioner Bolt $12
Idler Pulley $27
Idler pulley bolt $2
Throttle spring and cable Lokar $120
Trans dipstick Lokar $88
Everything was purchased in the US - so prices are $US.
Main issues -
TTI Mounts MM57A, - $140 - Needed serious modification, including cutting and welding - Guys in the US have had similar issues - TTI aren't interested.
Motor ends up too high at the front and "skewed". Final estimated workshop cost - $300
Headers - Took a gamble that the "shorty" "tight tuck" headers from Street and Performance would fit - Right side was a disaster (Mainly due to our steering box location) .....total re-fabrication - $1400 total outlay inc labour.
(This was NOT S&Ps fault...the work still cost less than custom pipes)
Brake booster bracket - Our booster and M/cylinder is on the right side. The booster interferes with coil pack removal due ti the offset of the K frame.
- so an offset bracket is required. Fortunately a local guy makes them. - $120
So if you have a carb - the intake and ignition is not the costly part of the job.
Pipes and mounts and brake booster on the other hand....
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
