I have ton's pictures of my blasting work, this is the most recent for me. Easy, heavy steel truck bumpers, used 20/40 coal slage.
BTW I have blasted silica sand that was delivered to the jobsite by the dump truck load in bulk. We would jack truck scales out of the scale pit's with 20 ton bottle jacks and wood blocks. Then sand blast the entire I beam structure underneath and then coat it in heavy lead paint back around 1980. I did at least 6 10X60' scales in my time.
I blasted this most recently. Easy work, heavy steel truck bumpers.
I rented this so many times that I bought it.
I blasted every inch of this truck tank and put it in etch and epoxy primer all in one day.
[image]http://[/image]
