I am having trouble with the brakes on my road runner. They dont stop the car very well. They seem to require an extreme amount of pedal pressure to work. panic stopping from 40 MPH I couldn't get the tires to lock up. I think it is a SSBC kit that was installed mid 90s. The pedal feel is ok, pumping them doesn't seem to make them work any better. I don't have a brake pressure gauge, but i can but one if needed. Right now the car isn't driven due to brakes. The brake lines look kinda scary.
The rotors are like 10.5 rear, 10.75 front, but only about 0.75 inch wide. Are they undersized?
Anyone know what kit this is?
Are they any good?
What spindles do I have?
Are the rear caliprs on upside down? bleeder appears to be on bottom.
Do any vendors make brake line kits for this setup?
Do i need a power booster?
It has a crate hemi using schumacher mounts - so not sure if I an fit one in.
Advice on how to assess/fix.
Help me get
again
Pics
