I just hope this used trans is going to work now,i saved it from a PENN state truck that had a engine knock and rust.
New filter, and while the pans off adjust the bands, as long as it doesn't look like the pan chunks my Dakota had it will probably serve well.
What fluid do you run? In my 3 speed autos I always use Type F for better shifting, and less foaming.
In my OD autos I have stayed with the Mercon 3 or 4 what ever number they are up to now. Not sure if the Type F will play nice with the OD stuff.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
