Quote: I had to cut a lot off of the aluminum bracket(A/C mount) to clear water neck. A/C compressor will have to be cut or ground a lot as well. I have a Professional Products Crosswind intake (Airgap clone).
Where are you putting the brace for the alt on the Crosswinds intake as well as the other brace that holds the A/C
Without these braces the big aluminum bracket will crack.
