Cab you are so right. It can turn a normal guy into a tear streaked raving lunatic. Other than living with it the only options using stock rockers are to send them out for correction,(they can make them better but not perfect) or find a way to dig through and check dozens of individual rockers.
Mine were redone and I bought another complete set from a member here. I checked them all and used the best of them to make a set. Here are the ratios I ended up with;
on the intake 1.69, 1.63, 1.66, 1.66,1.67,1.66,1.65,1.63
the exhausts, 1.53,1.52,1.51,1.49,1.51,1.52,1.53,1.50
The net differences in lift on mine are only .026 on the intake and .017 on the exhaust, I can live with that. It still bothers me but it's much better than most.Dave
