To remove the old bushing with the motor in the car ...
1) pull the oil pump
2) get a length of 1/4" threaded rod and 2 coupling nuts and a couple washers the same o.d. as the bushing.
3) make a THICK plate that will span the distributor hole. drill a hole in the middle slightly larger than the rod.
4) drop the rod down through the bushing and out the bottom. Install the washers and one coupling nut
5) pull the rod up till the washers contact the bushing.
6) slip the plate down over the rod and against the distributor hole lips
7) install the coupling nut and tighten it till it yanks the bushing out.
I reverse the procedure to install them - I like to "pull" them in rather than pound them.
X2...
I use the same 3/8" all-thread that I pull front (727)pumps out with
Did the whole used dist. drive thing but like you said.. No
