You do know that Indy makes cast iron heads also right??? Maybe check out some of the Indy dealers for a possible trade-in value for your MW heads Give Nick a call at www.compu-flow.com ![](/ubbthreads/images/graemlins/thumbs.gif) At least all your other parts will work ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) Gus
I have found the need to clarify some things. Class rules state OEM Iron heads. I already have some Max Wedge Replacement heads with correct casting numbers, ported, and assembled. I had them before buying an engine with these aluminium heads on them. The engine has the correct pistons, a decent camshaft and a ton of good parts that I would have spent a bunch more money on building myself.
I do appreciate all the advice, its all been read and tossed around.
Michael
93 W250 CTD getrag, Bosch 185 injectors, AFE air filter. Trailer puller, daily driver, 90 W250 CTD 727 with smokin 5" stacks. Off road truck
75 Dodge W200 440 4spd 4x4 locked front and rear, twin disc clutch, E85. Pulling truck
