works for some,not for others I guess
I have been on the side,miles from any thing cause of the crap,leanburn no better
spend $$ on this,that,some of those and still not run 1/2 the time
throw in points dist and it revs till it blows
I geuss I should also add that...I do this in conjuction with adding headers and a stock 4-v intake,use a early to mid 70s chivy Qjet or a eddy carb at the same time
cant stand the wimpy 2-v carbs on a teen
and with a stock 2 -v cam it seems to be a big boost in drivability and performance
then on to 360 heads(yes I know it lowers the comp)and a cam swap,stock high stall tc,then add gears
72-73 was the first yrs for the elec ign
and they start with smog air pumps,feed back carbs by mid 80s
