I see you spec'ed a forged crank and I beam rods, I would replace the I beams with H beams, to many stories of problems with the I beams. I had a reputable builder do my short block assy and spec the cam, he recommended a Bullit solid roller and Howards lifters, 11 to 1 compression with Eddy heads. It has over 200 runs in the 10's with no issues. Went 9.94 with 6.27 in the 1/8 a couple weeks ago. My Dart weighs about 2800.
70 Dart Swinger, 2850 lbs SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
