Quote:Quote: ...Over 600 lb/ft from 2000 up to 4000 RPM. Pretty much matches my Cummins diesel...No offense, but that sounds just a bit overly optimistic for the sum of the parts in a pump gas, sub 4" stroke engine.- 400 block, 440 steel crank w/ reduced main journals, - ported 440 Source Stealth heads, 10.55:1 - Comp hydraulic roller cam, XR274HR-10, 224/230 110°LSA- 383 style Six Pack intake
