If I understand it correctly the larger bore gives you less pressure and travel, I know mine doesn't travel very far.
Bob I messed with the adjustments when I installed the valve and it doesn't take much closing to make it hard to stop. With it wide open the car just sits down and has never locked up the tires, front or rear. I will at some point try a 1" bore to lessen the pedal effort and raise the pressure.
