I noticed the approximately 45 degree angled cut into the main caps, so do the blocks webs also have the 45 degree cast into it, or is it a hollow space. If it is cast into it, wouldn't that be better support for the main caps, instead of having a 90 degree angle that would cause stress/cracking at the webs. In reality more support for the webs.
there's an open hole where the cap is cut to 45. no support to the block in that area.
machine shop owner and engine builder
